FX to Out 1-6 possible?
I own a CQ20B and I have not found anoption to control the FX return level of a shared FX to the Out 1-6.
There is the “FX Level to LR” controll, which is obvious.
The “FX Send Level” control left to it is unclear to me.
I it’s not posible today, I would request an addition Tab with “SENDS FROM FX Unit” to controll the levels on the Out 1-6.
Have you checked out p. 48 in the manual? Looks like from the Processing tab, you can get to ST INPUTS / FX tab, pick your FX unit channel, then send to pick LR our outputs 1-6…
That’s it, thank you BubbaJ, I found the FX to Outputs sliders in the processing tab.
I was playing around with the MixPad Software without having the CQ attached. In this case only ST IN / USB / BT is showing up in the processing page, but not the four FX units.
Glad to hear it! It’s funny - I actually had the same question a month or so ago and I had forgotten to look it up. So it was helpful to hear from you that it did the trick.
