Hello,
I’m not sure how I got my mixer (GLD-80) into this state exactly, but when I have FX1 assigned to a strip, the strip’s display stays dark and its buttons do nothing. I had been experimenting with the FX Insert feature when this happened. I’m running firmware 1.51. Any ideas how I can get my FX1 back to normal? Thank you,
It’s normal. When an FX engine is configured as an insert you don’t get normal send/return faders to work with. Instead (most, if not all IIRC) the FX have a dry/wet control. If you want your faders back you’re going to have to change the FX routing from insert back to mix>return.
Thank you so much. Sorry it took a while to follow up. This resolved the issue.
