Fx1 send on Custom layer
Hello
I have an Allen & Heath Qu-6 digital mixer and I would like to know if it is possible to assign an individual FX Send control for a specific input channel to Custom Layer A.
For example, I would like to have two separate faders on Custom Layer A:
  • Fader 1: The normal channel fader controlling the singer’s main mix level.
  • Fader 2: An individual FX1 Send level for the same singer, controlling how much of their vocal signal is sent to the delay effect.
I need both faders to be available simultaneously on Custom Layer A, without having to switch to the FX1 Send mix.
Is this possible using the Qu-6’s built-in Custom Layer and Strip Assign functions?
If it is not possible directly, is there an alternative way to achieve this, for example using MIDI control, an external controller, or another feature of the mixer?
Thank you for your help.
Best regards
May I ask why you need this? Sometimes, there is a solution that will work for you but doesn’t need both of those specific faders available.
For example, you could select the input channel and press the channel to all mix button. That should show the send levels to Main LR and Fx1 simultaneously (together with all other send levels from that channel to any destination). While this is not exactly what you asked, it makes both faders you requested available at the same time.
I believe the following should also be possible on the QU-6:
Patch the singer to two input channels, e.g., 1 and 2.
Send channel 1 to all the mixes you require, but not to the FX.
Send channel 2 only (post fader) to the FX, but not to mixes.
However, the QU does not appear to have a “ganging” function that would allow you to link the processing parameters of the two channels, should that be necessary.
Alternatively, if the delay is intended solely for the singer, you could position the delay’s send master fader right next to the singer channel’s fader.
You cannot add a fader that represents a specific channel’s FX send level.
That being said, I don’t think you need to. I believe the newer QU models (you mentioned using an QU 6) have “Mix” buttons on each fader. This means that if you want to easily adjust the levels of your vocal channels being sent to a vocal FX, all you need to have is a custom layer with all of your vocal channel faders and the FX send (obviously you can have other channel on the custom layer too). Then all you have to do is press the “Mix” button on the FX send fader and it will “flip” the faders to represent the send levels for that FX for each channel. This means your vocal channel faders will change from representing the send level going to the Main LR mix to representing the send level for the selected mix (the FX send in this case). This is actually a better way to handle it IMHO because you don’t need a unique fader for both the channel and the FX send level for every channel assigned to the custom layer. You just need the desired channels and the single FX send fader and you can easily control ALL of the channel’s send levels to the FX simply by pressing the “Mix” button on the FX send fader.
That being said, I’ve never used the new QU series console, so I am basing my answer off my internet research and not actual experience on the console. There is a chance that my research is wrong.
Small clarification: They don’t have Mix buttons on the fader strips but they have Mix buttons for each Mix and for each Fx Send (basically the same as the SQ models). They are located on the right and behave just the way you describe them and you don’t even have to put the FX send to the custom layer, just the input channels you want to mix.
That being said, I am still not sure what the use case is that @Jiri_Varejka is asking for.
If you just want singer mic plus FX send for singer to be on any layer, sure. The FX must be set for send/return to itself not to any specific mix.
Clarify what exactly you’re needing this to do if other than putting the faders on the control layer.
I have a Qu-5 and have used all 6 to racks.
Just in case the OP doesn’t reply to you anymore:
You need something like this, for example, to manually apply a classic pop/rock music FX: Lightning-fast fading in a rhythmic delay always exclusively on the (usually) last sung syllable.
Copy. I guess in hindsight, it probably matters little exactly what the use is, but it seems like you’re saying. To quickly accentuate on the fly.
Or also to keep an eye on something (e.g. a fader position of an FX or a monitor send) at all times, and to be able to access it immediately whenever needed using this dedicated fader, which can placed exactly where you need it.
I know what your talking about …think Pink Floyd “Comfortably Numb” In the “old days” I would grab the delay FX send knob on the vocal channel. Today when that kind of delay effect is needed I’ll put the delay FX send master into the custom layer.
AFAIK you can only place the master send and return, on a custom layer. But if you’re not using all your FX busses, you could dedicate one bus and master to your lead vocal.
Wow - you mixed them!?! :open_mouth: :man_bowing: - :slightly_smiling_face:
Oh I wish I had!!!
That was in reference to when I have ran sound for a few bands that covered Comfortably Numb and a Pink Floyd tribute.
Same concept for mixing any song that has a signature one word or phrase repeat delay FX.
