I am using SQ 6 Board,getting lot of noise (Hiss) on the live recording on outdoor locations.
Need help to get rid of that external noise.
Regards
Regards
Hi Belly,
Does this only happen on outdoor shows?
Could you forward an example to support@allen-heath.com please?
Alex
I’m having a big problem with SQ6 recording. I use the reaper program to make my recordings with a Macbook and when I record using SQ as an audio card, after about thirty minutes of recording the audio starts a very strange noise that can not hear anything, just an unstoppable noise , I came to think that the problem was on the Mac, but as I also have the console QU SB I decided to do a test and put to record two tracks on the reaper using the same Mac and incredible as it seems I recorded but of 4 consecutive hours and no problem appeared . Then I decided to do another test now recording with an external HD by the SQ driver and the problem appeared again. Is any of you having the same problem?
lot’s of people having the same problems
the suspects are the USB chipsets in modern computers and assorted hard drives
Also can a console QU sb and I record with the same Mac and the same HDs that I record in the SQ6 and I have no problems, the problem happens with the SQ 6. Is it not any console software error?
