I have a GLD-112 with a Dante card installed for multi-track recording. I would like to add a GLD-80 as a monitor board. Questions…
- will this work?
- do I need a Dante card for each console ?
- do I need a gigabit switch to connect the multi-track recording computer ?
- Will I be able to add an AR-2412 to the monitor board? - If so, can I send those inputs to the main board as additional inputs?
Yes it works
You need 1 dante card per console
No swith required. You can connect the multitrack recorder to the secondary ethernet port of the dante card. It must te configured in switch mode.
Yes you can still use a 2412 and split it for FOH. For each dsp channel you can choose any input in the patch section or pre-amp page of the channel at the FOH board. Keep in mind that the monitorboard is owner of the preamp gain.
Regards,
Pascal
