Hello,
Is there a guide available for opening up the console to clean it?
I can see through the fans that there is dust everywhere inside my board, and would like to give it a good clean.
Hoping for a document, instead of just going for it.
I didn’t see any document so far but there are some pictures here in the forum.
It’s not that hard: turn the desk upside down and go for it. There are a lot of screws but nothing complicated. It becomes a bit more tricky if you want to open it all the way but maybe it’s already enough for you to open just the bottom.
My advice: install airfilters after you have cleaned everything. I have one outside of the power supply which I can change/clean without opening the desk.
It is not so complicated to open this desk, but if I remember right, there is some cables which are very tight when you open the chassis. Be careful and good luck.
