Last Sunday (4 May, 2014), i had the console freeze during a service (show). it did not come back to life, was frozen for well over 20 minutes!, and I had to power cycle it between services to get it come back to life. unfortunately, our turn around between services is very tight, so I did not have the luxury of booting it up in debug mode to see what happened.
One thing that may be a clue here, is that we record services to a USB thumb drive. the thumb drive was fairly, but not completely, full at the time the surface froze. fortunately, it froze in the middle of the message, so the main mic was life when it locked up.
Firmware = 1.40 - Rev 13807
Surface Board driver = 1.1
DSP Board driver = 1.3
Motor Fader Driver = 1.1`
Help set = 1.4.0
OS = 2.18
This was my first freeze while in performance. It has paused at home while experimenting and exploring with allot of the features being used. Features like Dante connected microphone receivers, a multi-track recorder via Dante Virtual Sound Card, wireless router, GLD remote, GLD editor and both my AR boxes connected. The above freezes were the same as below.
This freeze was only about 15 seconds long during a performance. I was the only one to know it happened fortunately.
Here is the background. Running version 1.4 software which was loaded two or three boot cycles previously (a few days previous). That days system components were very basic. One AR2412, D-Snake and the GLD80. At the surface I had only the single D-Snake cable, Mains AC power, MP3 player, headphones and a local handheld microphone. USB sockets were not in use that day, no Ethernet and nothing else was connected to the GLD80. It was outdoors at the end of extension cords but I am POSITIVE I was the only person on that 20 amp circuit. My amplifiers and the entire band were on three other circuits. The electric service was modern and in good working order.
System played background music about 2 hours without issue. At the freeze, the band was performing. I was either adding names to the scribble strips or routing reverb to one of the channels, I forget which. The touch panel froze as did the soft keys. Audio passed unaffected. Fader levels responded normally. After the freeze, all returned to normal. I was able to rename inputs and modify the effects at will, without issue. Gig finished without reoccurrence of freeze.
Since updating to 1.4 firmware 3 weeks ago, our gld80 has lost connection (due to system error) with our ar2412 and ar84 stage boxes twice during shows. Thankfully, audio continued to pass through the system and we simply had to clear the error on the home screen to re-establish connection. In both cases, we didn’t know about the error until after the show was over and we examined the show log.
Interested to hear if others have experienced this issue since going to 1.4.
Aside from these occurrences, we are extremely happy with the latest update. The new features have been amazing. Thanks A&H.
I have a big week coming up with a major star concert followed by a week conference live streaming. I have an 80 with 1.4 and 112 will 1.3 I have not gotten around to upgrading. I am thinking of hanging off and using the 112 and not upgrading. Have never had it freeze. This one makes me nervous.
GCumbee–I can understand your concern. Might be a good idea to have the 1.3 available. Still, I want to be clear that we never lost control of the show/mixer. Our engineer mixed the concert from beginning to end. I only noticed the issue between sets. The home screen said there was an error and that the mixer had lost connection with the stagebox (not sure when this happened). I pressed the error message and connection was re-established.
I had 2 crashes during pre-production with 1.3 (while configuring outputs and FX). Since going to 1.4, crashes have not occurred.
After a freeze 2 months ago, I have checked the setup of my console thorowly, going through every single detail that was assinged… Then I unnassigned whole bunch of stuff I don’t use, setup the console for the type of concerts I usually do, and since then I had more than 5 shows, and the console worked without a problem…
Hey Guys i had the same issue you all had it happens when any network cable in your network hub gets shot or (badly crimped)
Here in my case i am using the office network with over 60 computers,
i changed the network cable from one of the 60th comp the problem was solved,
i suggest use separate network for remote,
after that i purchased new Network hub for limited devices.
problem solved:)
Had a freeze mid service yesterday that lasted long enough that we were prepping stage people for a pause in the service for a reboot. Thankfully it came back before we to the end of that service segment. After the service it completely black screened and become totally unresponsive, with HD errors coming up on the screen. I am wondering if A&H is using a cheap supplier for the Hard Drives?
We did. Ours went back to A&H a week or so ago. We used it while waiting to get a loaner in. We didn’t have issues during those usages but were a fair bit nervous about it.
And for what its wroth, A&H warranty policies for getting service are pretty horrific. I wish we had known about them before we purchased.
Hi Luca, we are lucky enough to have a close relationship with the A&H dealer in my area so he loaned us a GLD while the other was being repaired free of charge. I did time the repair in a Month that it would not be used in the hope that i would not need to lend a console, surely 4 weeks is enough to do a 1 hour job that the dealer could have easily done??
However it took 2 months for the Fix to be done, as well as a lot of phone calls and emails to TAG (Aus distributor) and the company doing the repair from both myself and the A&H dealer asking what the hell is going on. I calculated that if i had to hire a console for every gig i did not have it in this time it would have cost me about $1500.
Furthermore, the company tried to make me pay for it. I told them it was under warranty from a factory default and my dealer made sure they paid for all of the freight costs.
The only saving grace was that when i asked them to pull out the DANTE card and send it to me as i needed it to link 2 GLD’s and many other dante devices, and it would save rebuilding the DANTE network when i wanted to sub the repaired desk into a show it turned up the next morning.
Last but not least, there is a loose screw floating around inside the GLD i noticed straight away when we got it back, so what do i do about this?
I was initially impressed by the communication of the A&H tech support, TAG was good in that they recommended an authorised repairer much closer in the hope that the repair turnaround was fast however they were little help in ensuring the repair took place. It still took 3 weeks for the desk to turn up after i kicked up a fuss, and continued to question what was going on.
What are the inconsistencies with the A&H warranty John?
7 Month old console froze pretty badly during a service, then completely crashed as soon as that service was over. I was seriously sweating it out. A&H corporate tech support stepped up immediately to replace the SSD (console spitting SSD errors out to screen.) However, the A&H national distributor wouldn’t ship me a loaner until they had mine. That was unacceptable as that room (permanent install) gets used multiple times per week and we couldn’t just live without it for for the transit time associated with sending ours down and getting a loaner back. Not to mention that its a new console. The only way A&H would ship a loaner beforehand so we could swap ours out was to invoice us first for that new loaner. Thankfully our sales rep stepped up and had A&H invoice their account instead of invoice us. We love our sales rep. We are however getting invoiced for freight, etc.
To add salt to the wound, in the end of this deal, we will have put out somewhere near $1K in freight to get WARRANTY service on our new ~$9K console. I am sure this warranty service will end up having cost us more than A&H. Why couldn’t a local rep just come and replace it at my location? Its just a computer that needed a new SSD. I am not sure whats more disconcerting, that this new console might end up being un-realiable or that if it has problems dealing with A&H will be an expensive and painful proposition. It can only get more expensive once its out of warranty.
We LOVE the GLD, its really perfect for us, but if we can’t trust it over time or trust A&H to support us in its use, then I wonder if we should have gone with Yamaha/Behringer/Avid. I need two more consoles in the near future and was just about sold on Qu. I might end up with LS9’s or X32’s after this experience.
My one-and-a-half-year old console died twice on me, first time (lucklily) at home during setup (wouldnt boot and got a new main board) , second time during a tour (USB failure, internal cables were replaced). Both times I opened a helpdesk ticket around midnight which was answered the next morning by 8:00. My German distributor recieved our mails as cc and joined right in to offer me a repair date immediately. Went there with the console and waited with a coffee until it got fixed at no charge. Despite of being really scared about the failures in the first place, I couldnt be happier about their service policy (here in Germany).
Thanks A&H and Audio Technica Germany for that.
I thought I would post an update. Our GLD is back from warranty service and was used again for the first time this week. It seems to be running great. It was really good to get it back. We ended up having to send it back to A&H a second time as a result of a small snafu during the console servicing. We found that immediately after re-installing from the original service. So far we are back to normal now though.
A&H looks to be stepping up and paying for all freight except for the initial freight to them so this service will end up having cost us a fair bit less than that $1k. In the end they made things right though the process was more painful than I think it needed to be.
Ultimately I think A&H needs to get some factory authorized field service reps that are available for use without having to ship your console across the country.
Ok, i join the club today my GLD80 it was sent back to Italy dealer for SSD change.
Good service about find the issue ( send LOGS to my contact, tell me in a couple of day that the SSD must be replaced), but now I HAVE TO KNOW wich is the main problem:
-are the SSDs a bad quality batch, so the problem is relatively easy to fix, changing supplier/type of component?
-are the problem caused by something else, for example some software bug (i’m just supposing…)?
In this year of using GLD, i always keep it in its case, alwais personally load in and out, so i’m sure that it doesn’t take any bash.
One thing that made me happy about GLD till now was is reliability, i had more time shows for 4 days with the GLD in full processing (46channels, all BUS full) without a issue, but now i’m a bit scared about the future: if the problem is a simple bad component (by the way, Avolites has some similar problem with bas UPS), for me is ok, but if the problem is in another place we need to know.
I refuse to do job with the scare that GLD may crash again…
I will very apreciate if somebody in A&H say something about this common issue.
Bye
Luca
Last weekend I had a crash. While copying High Pass filters to all channels the surface stopped responding. Normally it comes back to life after about 1 minute. This time it didn’t had to switch off-on during the show (which is not funny at all).
Last weekend we got a surface freeze, too. It happend while configuring custom faders in the iPad app. The meters on the app were also frozen. Fortunately it came back to life after a few seconds.
If you haven’t already take a look at our new GLD firmware release v1.42 which we anticipate will resolve issues relating to unresponsiveness of the user interface which many of you have reported in this thread.
