Today i was starting day two of rehearsels for tomorrows gig. Choir, full band, and some other stuff. Then my mixers work-surface “froze”. None of the knobs and buttons worked (other than the ones lit when it froze), but the touch display seemed to work as it should, though the mixer would not shut down correctly (I pressed the “Yes” button, but it just turned grey…), mixer still passed audio, luckily. Eventually I had to turn it off by using the “on/off” switch…
Scenario: GLD80, AR2412 and AR84 linked, no cards in the mixer, no routers or pc and pc’s connected. Gig was indoors, and the board was not moved since yesterdays sound-check.
Afterwords the mixer repeated the same procedure every time it turned on, removing the USB-stick did not help, resetting the mixer did not help, and installing the firmware (1.02) again did not help. Every time I started the mixer and hit some of the buttons, it froze after a minute or two.
Quite frustrating indeed, when the choir, conductor, band and MC’s all asking for monitor-adjustments which i could not give them… We had to stop everything, and people went home.
Seven hours and many attempts later the mixer is still not up and running. Disconnecting everything did not help, and it suddenly would not even boot! The display showed som odd graphic coloring, and there was a message about "Xorg and a lot of numbers repeatedly flashing on screen. After a while (and some more attempts to reboot) there was a message telling me “no contact with motor faders”…
Show starts in 16 hours, and the only other GLD within range is 4 hours drive away, 8 hours round trip… This could get exiting
I’ll let you guys know how this turns out (with the mixer I mean, the show is another story) when i know some more…
PS: Pardon my typo’s. It’s two o’clock at night here now, and i need some shuteye. DS
Willy
FOH-tech.
GLD-80
AR2412
AR84
