GLD 80 Not Passing Inputs to Outputs Upon Audio Config Change
I have a GLD80 setup with a bunch of inputs, many going into subgroups, then a bunch of outputs that everything is being routed into, I added a matrix, and I had enough resources, I didn’t delete any AUXes, Subgroups, nothing, just added the matrix, and the audio blipped, then completely stopped passing, I was seeing signal from the inputs, but nothing on the outputs, nothing on the groups, I double-checked and confirmed all routes, it should have been passing audio, but it wasn’t. Rebooted the console, still nothing, I had to recall the previous scene to get it passing audio again, but nothing else should have changed except for the added matrix output option.
Suggestions?
