Problem with “softkey” “Scene recall”
I save and scene, set softkey for scene recall.
It seems to set ok but you can only use it once.
You can select the softkey and is recall the scene but if you try to use the same softkey again at a later time it has lost its link.
I saved the show to memory and recalled the show and it remembers the softkey but it only works once.
Is any body having this problem is this a software bug?
Rupert
The logical reason is that if you recall the scene, the soft-key isn’t setup to recall that specific scene anymore. To verify, load the show, recall the scene with the soft-key and then go to the soft-key settings and see what is programmed under that specific soft-key. I bet is not “recall that specific scene” anymore.
Lieven
T112/IDR48/R72/IDR16/xDR16/2ACEcards/IPad1
Save a tree, eat a beaver
If you are in scene A and recall via softkey to scene B, the softkey also needs to be configured and saved in scene B (softkeys are currently per-scene, there is not an option - yet! - to filter them).
Yep, you’ve recalled a scene in which your softkey assignments aren’t the same as they were in the previous scene.
Can softkey assigns be scene safed?
Chris
Chris
In practice it probably doesn’t matter. There’s no general “next scene in cue list” softkey function, only recall of a specific scene, at least as of v1.0.2 of the firmware.
It’s still possible, as I understand, to set up a show where you want to advance scenes via softkey. However, the “advance scene” softkey will be different in every scene…
-in scene #1 the “advance scene” softkey will recall scene #2
-in scene #2 it has to recall scene #3
-in scene #3 it will recall scene #4
-etc.
Therefore, in any show using softkeys for advancing scenes you can’t scene safe them.
