GLD and Waves SoundGrid
Hello fellow forumites,
This is my first post here.
I´m about to purchase a GLD System with Waves Plugs.
The flowchart in the user guide (can we even call it that way[:wink: ]) shows Insert points on input channels and mix/master/matrix busses, but specifies the possible insert connections only as “Skt or RackFX”.
At the beginning of the signal chain, only physical XLR and chinch inputs are called “Skt 1-48”, not the Card I/Os.
Will I be able to insert those 64 I/O points from the Waves soundgrid connection here?
If not, how would I be able to use Waves’ plugs with the GLD?
Any experience reports about all aspects of Waves integration would be highly appreciated!
Thanks and greetings from Germany
Pit
The diagram is missing the I/O port as an option for inserts - but yes you can select the I/O port in the software - sorry for any confusion.
Antony Jackson
Software Manager
Allen & Heath Limited
That’s what I was hopin’ for,
but thank you, Anthony, for making that clear…
