GLD editor for dummies
I am starting with setup of a yet to be purchased GLD-80. I don’t see a way to add an AR168 to the I/O.
All possible audioracks are accounted for with what’s already there. In the I/O tab dSnake is whatever’s plugged into the dSnake port, up to 24/12, dSnake EXP is whatever’s plugged into the expander port of whatever’s plugged into the DSnake port, up to 16/8. It shows the maximum I/O that could exist, you just use as much of that as you have.
If you’re plugging an AR168 into the dSnake port just use the first 16 in and 8 out on the dSnake tab.
Chris
Thanks for the reply. I am starting to understand some basics. One that I approached in the wrong way was assigning inputs to strips. I started by trying to name the strip and assign an input to the strip, wrong. Assign a name to an input and assign it to a strip. I claimed “for dummies”.
