GLD Editor with Windows 10 and high resolution screens
Hi folks
I’m sure there was some discussion in the past about GLD Editor on devices like the MS Surface that have a very high resolution, meaning that the Editor ends up super tiny unless you manually adjust the resolution of the display or use an external monitor. Well, I’ve found a workaround at least that works much better - in Windows 10 (I’m running 1703, Creators Update) you can adjust the application compatibility settings to override the DPI scaling.
C:\Program Files (x86)\Allen & Heath\GLD Editor 1.51
Right click the GLD Editor executable and go to Properties > Compatibility. Set “Override high DPI scaling behaviour” to System. Much better!
Hope this helps someone :slight_smile:
