GLD Remote on existing network
Is it possible to use GLD Remote iPAD to connect to GLD112 using existing and on the same network (GLD112 via Ethernet and iPad via Wifi).
Our current setup is GLD112 is used to output sound to multiple rooms, and standalone router signal is too weak to travel to next room.
Rgds/
You need Access point or extender. If you have router wifi why you don’t use a wifi extender in your local Lan? you put one or n.x extender inside the room when do you need wifi connection.
