My gld is taking almost 3 minutes to turn on. It has the new version 1.30. Please help me.
Its probably the DHCP setting for IP address in networking config. Try disabling that and giving it a fixed IP, if it can’t find a DHCP server it will basically hang for quite a while until it times out.
That said, I have noticed the boot times on 1.3 are quite a bit higher than the old versions.
Dave
The DHCP is off. Do you know what can I do more. Maybe to reset the console?
Thank you for your help
I found that even if you change the IP from the default it takes longer to boot. (192.168.1.50)
v1.3
