We just purchased the GLD-80 with the GLD-AR2412 digital snake. We have a couple of questions:
We are using Aux’s for monitor mix, can’t figure out how to apply FX to Main L/R for certain channels and remove the FX from the Aux’s for those channels. At present when we apply the FX it affects all the Aux’s and the Main L/R. How do we fix this?
How do you adjust recording level to record to usb feature, and how do you feed the recorded audio to the Main L/R on USB playback feature.
quote:1. We are using Aux's for monitor mix, can't figure out how to apply FX to Main L/R for certain channels and remove the FX from the Aux's for those channels. At present when we apply the FX it affects all the Aux's and the Main L/R. How do we fix this?
To assign/de-assign FX from the main mix, press the MIX button on the mains strip. then hold down the MIX assign button and press the FX return channels you wish to assign/de-assign from the main mix.
To assign/de-assign FX from an Aux channel, press the MIX button on the Aux you wish to change the routing to. then hold down the MIX assign button press the FX return channels you wish to assign/de-assign from the main mix
quote:2. How do you adjust recording level to record to usb feature, and how do you feed the recorded audio to the Main L/R on USB playback feature.
To set the record level you can use a Matrix output to send the main mix to the USB record. The fader level for the matrix then becomes the send level to the USB record.
to send the USB playback to mains, SEL a spare stereo input/group/Aux channel and select the channels source to be from USB.
Question: Are there plans in firmware updates to extend the delay times in the FX delays? 1.36 sec is a bit short for tap tempo applications that I need.
