Global assignments?
Is there a way to set all assignments (“ON/OFF”) to a given mix (AUX1, for example) in one fell swoop? I have perused the V1.4 Reference Guide and skimmed this forum and not found a way. For that matter, it would be nice to have global control of other settings, such as delay ON/OFF. This could save a lot of button pushing and checking during initial setup.
I realize that going forward I’ll have scenes for every purpose and this will be less of an issue.
Overall, I’m very impressed and pleased with the UI. Even this old goat had it up and passing audio an hour after taking it out of the box, and that included a surface firmware update to rectify a version mismatch with the mixrack.
Thanks.
Best,
–Frank
mix button on the mix while holding the assign key
but I agree that a multi select function would improve the workflow for large channel counts
Thanks so much! I was well aware of ASSIGN + MIX applied to an input but somehow missed ASSIGN + MIX (and PRE + SEL) applied to a mix. Does exactly what I want. No more silly questions from me. --Frank
don’t make promises :smiley:
