Group to Matrix
I don’t know if I’m missing something, but is there a way to select a group and adjust the sends to multiple matrices?
I know you can do it the other way around, hitting mix on a matrix and choosing which groups go there. But is there a way to hit mix on a group and then send it to multiple matrices?
Working with lots of groups and matrices, it would make my workflow a lot quicker.
as far as I know not at this time…
I just tried it… it really only works in one direction, so select a matrix and then mix in a subgroup
that surprised me a bit now, because normally it should also work in the other direction (i.e. select a group and mix it into the matrices).
That is my thought as well. It just takes a bit more time having to select the matrices. And not having a way to look and see where a group is routed is quite odd. I’ll post it in the feature request as well.
