Are we able to program groups into the Qu-16? I would like to control all the drum mics on 1 group, vocal mics on another group, etc.
Thanks.
Hi! Not really! No DCA and no Groups… but there are only 16Channels anyway! you should be fine with just use your “16Fingers” at once to control the whole drum! i would like to give you another answer sorry!
This is not possible on this desk.
I had though it may be something I’d miss, but to be honest, as I have only 16 channels, it’s not really a problem.
Groups are almost a necessity in corporate use. With a handful of Lav mics, hand held mics, and playback devices, it would be great to be able to throw a graph on all my lavs without having to eq my entire system to them. I would even be pleased with the ability to patch one of the mixes to the LR master. Do any A&H technicians have any plans of updating to allow this?
haven’t tried this yet but can yo go out of a stereo mix (outs) then back in to the board via a stereo in? You would have to have the faders down on the main mix though.
I need to try this myself!!
Dwight
having this would be very usefull. If a band needs almost all the 16 mono channels there is no way to have all that’s important on the custom layer. If you could reduce the drums from 5-6 to 1 fader there would be room for FX and maybe mix masters on the custom layer, pause music etc. That would be great!
Well, you could always do it the old fashioned way. Assign drum mics to say Mix 9-10. Remove them from the L/R mix. Patch cables from 9-10 out to ST 1 L&R in. Use ST 1 as a group master. That is the way we did it in the old days. I just tried it. Works well. With a 2412 you can patch from OUT 9-10 over to 17-18 in. Will require a pad and appropriate gain setting…Put the ST1 on the Custom layer along with single mics that you are using. Now you have your group master…
@GCumbee
You don’t have any noticeable delay? If not, i may try this at this weekend.
No delay that I could tell. I wore headphones just talking into a mic. Could not perceive any chorusing or delay between sound to my ears and the throughput.
I patched it on a AR2412. Be careful not to get a feedback loop. I did the first time. Let me know how it works for you. Poor man’s way to get a group…
Groups would be nice to have when you are running out of faders in your custom layer. Then needing just one fader for the drums would save 4-5 faders for other things.
The solution using the hardware patch is a work around. I would prefer to not have any extra AD/DA conversion for this.
Agreed. But what little listening test I did at matched levels I could not tell any difference. I think say on live drums the benefits would far outweigh any minor loss. Conversion is so good these days it is not worth the worry. I was a part of converter testing years ago done at my studio in Nashville. We proved our point in that no golden ears could really pick out the most expensive converters. In fact some cheap ones were just as good as very expensive ones. In the big picture things get lost and we get too strung out on stuff like that. No one hears the console in a recording. They hear the music and the song.
Thx for your insight. Another disadvantage of the hardware patch is that you loose one input per group.
I had another idea without the hardware link.
Set all the group channels to e.g. Mix5-6.
deactivate the channels in LR.
Then use the Mix5-6 as input for the FX3 or FX4 (back panel)
I hoped that the empty rack option of FX3/FX4 will do the trick,
but with this option the signal does not go thru the FX-modul.
You can use a mod-fx for FX4 , then the sigal is here.
But the signal is not dry.
That means if it would be possible get a dry signal thru the FX block, then you can use it as a group.
disadvantage: one FX Block is needed for it.
Have to say, that’s a brilliant idea Ruben!
I see groups as a necessity. And I don’t agree with you only have 16 channels so why do you need groups. I use groups all the time, for mixing and effects and signal processing.
I have ordered a Qu-16 for my church and the absence of groups has made me think long and hard about my decision.
In my own PA I’m currently running a 16 channel 4 bus analogue desk that I’m looking at upgrading. Unless the Qu-16 gets subgroups or DCA’s, I’ll be buying a ZED420.
I don’t necessarily think it is a necessity, but I would prioritize it pretty high, particularly given the utility of it in the iPad app and the fact that it seems like every competitor out there has it. This seems like it would be a fairly trivial thing to implement in the software. (He says, knowing full well that he often experiences the ‘How hard could it be?’ discussion with his own managers in software)
Sitting in the same boat here… weird that that the possibilty of just put up the faders of the mixes in LR mode doesn’t send mix → master… for me that would be the logical wau instead oiof a using thoose as level faders for the extetnal mix outputs…
Let’s hope fore a update… the empty effect rack workarround could be a solution. But how hard can it be, the mixbuses can’t be hardwired since the efx → mix as send option for efx3 and 4 is there or?
I’d like groups or DCA, too. Custom layer becomes much more useful.
Is there any way this could be done using the existing mute groups, but applying a fader to them? I realize it would have to be assigned in the Custom Layer only without some label finagling, but…
Would this idea maybe get us close to what we want?
Seems like the only logical method is to have routing from stereo mixes into the LR out. Say a routing screen that gives choices on the LR out to accept the Main LR and a combination of the stereo mix busses. Just don’t know if the DSP or hardware can add that.
