HD24 recording from MMO Problem
I am sure that this subject must have been discussed already but I cant find it.
We have an iLive T112 with an iDR48. The iDR has an MMO card installed. We are trying to record from the ADAT outputs directly connected to the HD24.
We are getting sporadic clicks and pops on some tracks during the recording.
I have found several ideas elsewhere to try including resetting the HD24 software and hardware which we have tried with no success.
Any help or advise would be appreciated.
R Ritchie
Hi Robert
Have you made sure that the HD24 is syncing from the ADAT input stream and not internal sync?
Regards
Sam
R Ritchie
Been doing this successfully for some time now…as stealth suggested, HD 24 sync should be set to “adat optical” also make sure you use appropriate “pro” quality cables.not the cheaper plastic toslink as they are prone to clicks etc…even though they do appear to sync lock…
RayS
R-72/iDR32/iPS10
Hi Robert,
I had the same problem with my mmo card.
The Optical ports on the mmo card where defect on mine,
they switched them with the correct ones @ Tmaudio and i’ve had
no problems since then.
This is a known problem with the mmo card.
I think you would be best off contacting the dealer with this information
Kind regards,
Jeffrey Vermunt
Soundservices
Sound Services
Same here - we got a replacement card. Ade
T112, R72
iDR32, iDR48
iStuff
