How do i use the Headphone port on the IDR32 with live editor?
Just the same as with the headphone port on the surface - there you can hear the signal thats pressed “pfl” for example.
So you cannot rout it differentially?
If you want a headphone mix at distance from the IDR32 near the laptop then you will need to either extend over copper or use a set of wireless in ear monitors. Is that what you wanted to know by routing differently?
Cheers
Richard
IDR48/T112
JoZee,
You can not route the pfl output on the surface differently than the one on the rack.
It has been requested to accommodate FOH/monitor mixing on one rack with separate PFL for front and monitor. The only way you can do this now is to use two racks connected.
regards Lieven
T112/IDR48
Save a tree, eat a beaver
