Help needed with Speaker Matrix Processor
I load LCR+XOSub from the Library.
I Fully Unassign the Sends and assign the following:
IP1 - Mains Out L
IP2 - Mains Out R
IP3 - Mains Out SUB
I don’t hear any changes when I turn the XOVR on. Do I need to set the Outputs? If so, how?
Thanks for any suggestions.
Did you assign the outputs as well (outputs on the mixrack?)
I assigned the outputs by loading the default show FOH-LRSub.
What i meant was - in the “output” tab of the editor or the page on the console - did you assign the speaker matrix outputs to your mixrack outputs?
Thats not done simply by loading the show.
Thanks for your help!
There is a tab called View Outputs in the SPKR Matrix panel. It reads as follows:
Output Targets
OP1: Not Assigned
OP2: Not Assigned
OP3: Not Assigned
and so on.
I use the Editor only and don’t see how to assign these outputs.
Open the ‘Setup’ menu in Editor and select ‘I/O Patch’. Then click the socket you want to assign, open the drop down ‘output source’ menu, select ‘Rack FX’ near the bottom of the list, select the FX unit output from the speaker processor then hit ‘Apply’.
Hope that helps,
Carey
Perfect! Thanks again!
quote:
And it helps to store this as a scene…
I mostly use scene numbers over 200 for configuring the surface and the complete system
SRV-AVB
R-72, iDR-16, xDR-16, Dante
