Help setting up DVS
So far I’ve been testing how to send signal from one iDR to another over Dante. Today I decided to set up recording on PC. Spent about 4h, but no luck so far. Maybe I’ve missed something or did not all I had to. What did I do:
  • opened Dante controller
  • started DVS, set to 48000, 24 bit, 10 ms
  • in ASIO tab set buffer to 256, latency 5 ms
  • in controller did patching from iDR tx to DVS rx
  • opened Sonar, selected ASIO driver
  • made some blank tracks, assigned inputs to appropriate DVS rx
  • on iLive did output patching 1-64 direct outs
  • armed Sonar for recording, but indicators showed no signal
  • tried to record … nothing was there
  • decided Sonar is kinda POS and downloaded Reaper demo
  • did input and output patching via matrix
  • armed channels- no luck, indicators not showing input
  • pressed REC, time was standing still (in Sonar it was running)
  • ran out of ideas so came here to ask what is wrong…
thanks in advance!
ddff
Maybe dumb question, but did you enable DVS? The big button in the middle?
Just asking, cause that was my first fault…
Don’t feel too bad if you make that mistake, took us a while to realise that was actually a button as well!
  • Jeff, A&H
Yup,
took me for a while to identify the button, but that was not a problem in my case. I just forgot to plug ethernet cable from control port to dante audio port. So I got audio running finally, however not satisfied with results- got HP laptop with i3, 3 GB RAM but when recording more than one track it sounds gapped, pitch is changing, stops for a while, etc.
Maybe gotta look for some hardware that’s dedicated to audio recording, like JoeCo or something…
ddff
Hmm. I am recording with an small Acer Laptop Aspire 1810TZ (Pentium Dual Core - not a really fast one) and had no problems so far.
Clock settings are right? Is Dante syncing to Ilive?
Yes, it looks kinda funny, my FSC Lifebook P7230 (core duo 1,2 GHz, 2 GB RAM) could easy record 32 channels, it started to skip audio at 64 ch, but that is logical for old laptop. Clocks are OK, it’s just computer and/or operating system’s ability to handle huge amount of data, I think.
I also tried with one huge box- IBM IntelliStation dual xeon 3.xx GHz processor, 4 GB RAM, 140 GB ultra fast scsi disk, same problem- 64 channels can’t be recorded. Did everything Audinate recommends about operating system, checked DPC latency- it’s about 100 us - far below green line. Don’t have anything more serious than that arround, will continue experiments with different settings such as latency, buffer size, number of tracks, etc.
ddff
Hi LV what cables you are using for dante? i had such problems when used regular cat5 cables when i have changed to shielded cat6 with Harting connectors everything fixed up.
agutin.com
2x iDR32 +MADI OPTION
MacBook,
desktop+2x RME HDSP MADI 2 X M DANTE CARDS
The cable is 1m long cat5e. Don’t have cat6 arround, but do you think that’s critical for such short runs?
ddff
Hi ddff
You do not have to use Cat6, but it’s always worth trying a different cable.
  • Jeff, A&H
