Help using Qu-24 live with Logic
Hi, my name is Nicolas and I’m the guitarist of our church band. We recently bought the QU-24.
I’m trying to figure out how to use Logic in Macbook Pro to simulate my stereo amps for live use.
My signal chain is: Guitar > Pedalboard > L in/R in QU-24 > Macbook Pro with Logic (via USB), where i have one amp simulator on each channel. My idea is to create a stereo setup. I’ve used this setup in an older digital mixer (Presonus) and it worked just fine.
The problem is, i have signal entering in Logic, in both channels, bust I just can’t process it in the amps simulators and hear it in the PA / headphones. I need to have the signal coming from my analog inputs, pass it through Logic, process in the amps simulators and return to the same channels in QU-24, vis USB. Is it possible to do that?
Thank you very much!
No.
Have you read the full manual?
It will take you through some of the options - you need to burn extra channels
