Hi Everyone,
Can someone please tell me how to setup a Mono Aux as an all pre-fader mix for every channel. Surely I do not have to hit the Pre/Post button a 128 times to switch a mix from Post to Pre fade.
JI
Hi Everyone,
JI
quote:
JI
https://iliveforum.allen-heath.com/topic.asp?TOPIC_ID=1341&SearchTerms=global,pre
RayS
R-72/iDR32/iPS10
Thank You!!!
A few more tips:
Remember that you can recall one of the Template Shows (Utility / Configuration / Show Manager screen) as a starting point for a new show or user. These give you a classic layout to fit your choice of Surface and MixRack, and with auxes set pre-fade for typical monitor use.
You can edit the settings after loading the Template and save them as a User Show as your personalised starting point.
If you are using Editor offline then you should first recall a Template or User Show once the program has loaded.
If you change the bus config you should first store the current settings to a Scene, then recall that Scene after changing the config. That will restore your pre/post aux and other mix settings.
Regards,
Carey
