High Pass Filter for Aux Sends
Would love to be able to set a High Pass filter on Aux sends.
the low band in PEQ should do this
You only have a PEQ on Stereo Auxes! For Mono-Auxes you have a GEQ! Low-Pass for All Auxe-Sends would be nice but not really a “Must Have” in my mind!
Every Mix has a GEQ and a 4-band PEQ, you can set the lowest band on the PEQ to high pass mode, The default range is 20-200Hz, if you need it to go higher than that select the full range EQ option on outputs via the pull up tab.
