HOME Button Fuction
with press to the HOME-key on the surface the function “GAIN” is put on the rotary knobs.
I would find it meaningful if instead of this the function “PAN” was selected. this is less susceptible to mistake.
+1!!! It’s been a concern of mine for volunteers from day 1. Far better to have to consciously choose gain over pan.
+1 pan instead of gains as default
+1, that or a function revert option of the rotaries.
Absolutely nothing should happen to the rotaries when pressing the home button. They should not change function if you ask me :slight_smile:
@ Tor - I disagree for most situations. IE - in our venue I definitely want “Home,” to default to the main desk orientation; including pots. That is a particularly useful failsafe for any place you might use this desk with lower-skilled individuals. IE - I want to be able to tell our volunteers, “If you’re ever not sure where you are and need to be ready to do something quickly in the main mix, hit home to be certain.” …now, if I could also choose, for those individuals, to have those rotaries default to pan instead of gain, that would be more useful. (Or perhaps an option to either default to a certain selection OR leave unaffected by home.)
maybe we can get a preference for that…
The dLive system should not be developed with uneducated volunteers as the user base. It is a pro desk, for pro users, and of course the Home should not do anything but take you to the home screen.
I think A&H add full customisable Home button on next time.
we will see if there are enough requests from other colleagues for this change.
I hope so … :wink:
