the possibility to use waves multirack or similar systems through an usb insert-point would be really nice.
signal is sent to computer over usb, is processed there and sent back into the channel.
hope that is possible somewhen.
thanks, andi
thanks, andi
Well,
It’s possible to do that, but!
The killer is going to be delay with any thing in this Catagory…
That’s fine on several effects like a delay
But real time outboard pc effects processing gets tricky to get everything bulletproof…lots of middle men…drivers…OS…hardware…software…
I’ve done this with other boards in varying brands and price points…and if everything is built right…which is out of a-h hands on most of it…
I don’t see why you wouldn’t just use the regular analog to outboard gear…that’s way more reliable and less to point fingers at different vendors and the Lag of the loop should be one the board end a hard number as for timing…
Just my take…
