How can I troubleshoot some tracks not recording in multitrack mode?
Hi folks,
I have a QU-PAC and using one of the thumb drives that is marked as approved on that spreadsheet. I did a couple of recordings without an issue, but I just recorded a rehearsal and four of the tracks didn’t record. All the other tracks recorded fine. They are all routed correctly. Can anyone recommend what steps I should do to make sure this doesn’t happen? I’m attaching this pic of the file structure because it’s interesting - all the tracks that recorded correctly also put that Dec 31, 1969 date on the files while the four that didn’t record correctly have the date of the recording and are all only 66kb.
But was there a signal present on those channels at the time of recording? Seems odd.
As far as I know, it is impossible for these tracks to have been recorded on the QU mixer, as this device does not know recording dates or times.
That is why all the other tracks also display this fictitious computer timestamp.
If you formatted your thump drive correctly before recording and these four tracks show the recording date as their creation or modification date, then you must have (accidentally) added or replaced them during a subsequent process on a PC (?) - whatever you did.
And that likely happened at 9:15 PM.
Was your board set at 96khz? At that sample rate it only does 16 channels - at 48khz it does up to 32 channels
Sorry, but as far as I know, nothing on the QU-PAC can be switched to 96kHz - neither the console itself nor the recording.
Also, you can only record up to 18 channels.
To add to SQUser’s correct response, this is from the Allen and Heath page for the Qu-Pac:
Yeah I’m sorry - I thought I was in the SQ forum….my bad.
