Hi i’m new Here ?? And have a QU-16 -it’s a Great Thing ???.
How can I Play a Channel as Solo, because I don’t found a Solo Button ?.
Kind Regards Micha
It’s called PAFL.
Have you got the full manual?
Yes, i know the manual ;-),
Sorry, I have certainly described not entirely correct, what function I’m looking at the qu-16th Is there a way to switch a channel solo on Main Out, without any other active channels to mute ago
Solo to mains?
Not obviously (at least not one that preserves mute states.
You could set everything in a mute group, then mute all, unmute the one you want, then unmute the group after.
However this will clear any legitimate mutes you had set before…
If this is for playback or something similar then you could switch scenes?
…or use the Alt-Out instead of Main LR…
I think the OP is asking for “solo in place.”
Thanks all, And yes I look for a Solo one Channel at Main out And mute all Other in one step (Soundcheck with / without USB Play-back (I’m the Frontmann of out Band And the FoH too ??). But it isn’t a Problem, if theres not a Solution.
Micha
Alt out in place of LR might work then - allow PAFL to default to LR, and then when you PFL anything else it will just provide that instead.
Risky in a live environment - but only if anyone touches the desk…
Hi bob, nice idea, but it’s to “hot” ?
You know the alt out has a trim…
