how to record with USB a pre-EQ signal?
I need a simple method to bypass any eq, parametric or graphic, in the usb recording.
It seems impossible, the only method I have found is: use a fx slot,make it “empty”, insert it on the mainLR (tha channel I want to record) and then on “REC” matrix (obviously put the “mainLR” send to -inf) use external input and point it to “FX slot” out “PO12”.
It’s not that immediate and, most important, I loose an FX slot, but it works and I cannot find any other way to do it, without remapping outputs or ad-hoc groups/auxes.
Any other suggestion?
Massimo
Take the EQ off your LR mix and send LR to a stereo matrix. Do your system EQ on the Matrix, send that to the PA, and record the LR directly.
Chris
