How to send Main LR to Dsnake AB168 output 1 and 2
Hi, I am new to digital mixer. Recently, the church acquired a qu32 and 2 AB168 equipment to replace existing analog mixer. We are able to setup stage monitor from dsnake with mix1. We don’t want to connect the main speaker from the mixer rear panel. We want to use dsnake to AB168 output 1 and 2 to connect to main speakers and with volume control from mixer LR fader. How do I do that?
KK Yeung
Go to the set up menu screen, select the IO tab, D Snake output.
From there you select the out socket you want and then using the encoder knob scroll through the choices.
