I wonder if there is a possibility to have one physical Input channel on two channel strips. These two channel strips should be INDEPENDENT. I’d like to split the lead vocals to have different EQ, compression and inserted effects on each.
just go to the strip you want to be the splitted one, select it SEL, touch the Preamp and then just change the input to the same as the channel you want to split…
For example, if you want to split channel 1, which is A 1, go to any other channel strip, and change it to A 1 and you will have a splitted channel without the Y cable…
Just to clarify the facts, their is no limit to the amount of input channels sourced from 1 IP socket, you could have all 64 channels coming from the same socket if you wanted. [ ]
When using multiple input channels from the same socket Analogue gain is shared but not digital trim.
I tried to share one physical input. Strip A is the “gain setting” strip. When I activate TRIM ON SURFACE on the second Strip which should be the “follower strip” both strips change to TRIM.
