HPF / LPF
Filters should be available on Mix Busses
Even if this was just a HPF this would help tremendously when setting up Fills, Matrixes, and Monitor Mixes where low end is counter-productive & not appropriate for the application.
HPF / LPF
I mean, I’ll never say no to having options, but you can get a high pass filter in either the main EQ or by using the NEQ.
You already have both.
