I believe I found a bug: can't stream USB past channel 22 on QU-PAC
I just got a QU-PAC after having a QU-16 for a couple years. QU-PAC should allow 32 in on USB. Even though the QU-PAC shows up as a 32 in/out device in my DAW, the mixer itself is only receiving audio up to channel 22 (weirdly the same as with a QU-16). Can anyone else with a QU-PAC verify if you are able to stream audio into your mixer beyond channel 22? And before anyone asks-yes I do have the USB B set up correctly in the input routing.
This is a brand new QU-PAC with 1.9 firmware.
It would surprise me if something this obvious had been missed by everyone…
Have you tried downgrading firmware to check for regression?
Yes, this does work (regularly using ch31&32 for PC return on both Qu32 and QuPac). Sure you’ve enabled all outputs in your DAW?
So the problem seems to be because the scenes I imported are from a QU-16. when I reset the mixer settings I can stream out of higher channels but when I load a scene that was originally created on the QU-16 I can’t stream above 22. Migrating to the larger system is becoming a bummer!
Feel free to pm me a seen for checking.
PM’ed
Sad to say: Works as expected. Can easily stream to any channel after sourcing them from USB-B. So issue isn’t the scene.
Sure you’ve enabled the additional upper channels in your DAW? If you’re on Mac you may try to assign the system playback to the upper channels and see if thats working.
If its the same computer used for Qu16, maybe the driver filters out the upper channels.
Strange.
As I mentioned-resetting the QU-pac mixer and then the audio streams correctly. It’s not a DAW issue. Very strange and I’m not sure what to do at this point if it works on your QU-32. Any chance you have a QU-PAC there?
Did the scene load the stereo tracks (17-18, 19-20, 21-22) into the ST1, ST2, and ST3 of the QU-32? Do they show up in processing page as “USB” even though they can’t actually receive USB?
well…sure enough I just tested it again this morning and I am getting the streaming to work correctly! Gotta love that. The only issue I need to deal with now is just copying over all those stereo tracks and their routing to different channels.
not this week, but this should not make a difference.
at least I have names "Drums", "Synth" and "Sy mar" on ST1-3, 17-22 seem to be empty.
after loading the scene channels 7,8,15,16 and ST1-3 are assigned to USB, but ST1-3 show "X". All other channels sourced from local input.
after loading the scene channels 7,8,15,16 and ST1-3 are assigned to USB, but ST1-3 show “X”. All other channels sourced from local input.
Exactly. So this creates an incompatible scene…one that works on a QU-16 but will not work on a QU-PAC without modification.
Is the routing the same for all your scenes?
If so, you should only need to re-patch once, then make the routing “Safe”. Then recall each scene & save it again with the new routing.
  • Not go a desk here to actually try this out on, but I’m pretty sure this is correct *
That would work for routing, but I’m pretty sure I will still need to manually adjust mix level sends for each scene (mixes are different for each scene).
