Idiots Guide to Effects in the QU-SB
How do I get a stereo reverb up for outbound (podcast) monitor sends 7-8? I need step by step for dopes.
P.S. I searched YouTube and here and didn’t find much. Some detailed training videos would be helpful.
P.S.S. There should be come kind of warning on screen when you patch a reverb to itself as it resulted in a horrible situation at church one day too.
thx
I have had that warning the first day I was at the nursery soundmixer school :slight_smile:
Select the reverb return you want.
Select the 7&8 Mix “sends on faders”
Push the revers’s fader up.
Note that it must be “ON” and if post fade, the L&R level must be up too.
By default, send to itself routing is set to “OFF” so it’s not that easy to do it by mistake. However, as there are many ways of routing things, through groups etc, it is important to think carefully about how where you send signal to effects from!
Hi Ronnie_p,
Would you mind deleting your nonsense post? Thanks. Oh, and FU.
