Hello,
I’ve bought a M-WAVES card fitted in my IDR64, the recording is OK but when I want to mix all tracks after the show (recording with reaper) with mi Ilive, I have some crunches/click in one or several tracks which are listening of course in the master section.
I use a PC (Windows 8 / Core I5 2,4Ghz / RAM 12Go / Gigabit ethernet), Soundgrid drivers Ok, I use NATIVE mode.
Just to explain : clicks or unpleasant noises are not visible on the wave form, only when Reaper read tracks and transmit on Ilive.
I’ve tried with ABLETON LIVE, same issue, with 2 others PC’s (windows 7), same issue.
Don’t you think I lose TCP/IP informtions from reaper to Ilive (i use cat6 cable), clock issue ?
I"m a bit disapointed because according WAVES soundgrid web site, it must work.
Regards.
Olivier
