iDR-Out
Can the iDR-Out unit be connected to the iLive system? I would like to use one in my amp rack instead of something like a xDR-16 since i don’t need inputs at that location.
Hi tophfro
Yes you can: fit an MMO (Mini Multi Out) card to the option slot on the MixRack. You can connect one or two iDR Outs via cat5 runs of up to 250m! - very handy for delay towers or distant amp rooms.
Download the user guide for the breakout box here https://www.allen-heath.com/series/idr-input-output-expanders/
there is also an AES / sdpif version too if that helps.
The MMO option card info is here: https://www.allen-heath.com/ahproducts/mini-multi-out/
HTH
A&H UK
Awesome! Thanks for the info Leon. Looks like i need to work up an order and schedule some play time :slight_smile:
