my idr48 do not light system loack so the surface do not conect
Fernando Lopes
Fernando Lopes
do you connect both cables (cat5) ace and network?
cheers
dave
allen&heath iLive-144 /idr 64 / idr 48 (i am convinced there is a yamaha conspiracy against the release of the dante )
Hi Fernando
Is it the iDR48 that does not show system lock or the Surface?
Just because there is no system lock on either the Mixrack or surface does not mean you connot connect your devices together successfully.
what does it say in on the touch screen when you try to connect the system together?
If you do not get system lock your system might not be syncing from it own internal clock.
Please explain your exact physical setup.
What IP settings is your system set to?
Can you connect over either ACE or Network only?
Regards
Sam A&H
The idr48 not shows system lock
The mixrack not conect.
I’ve tried another idr (ace) and the mixrack conects to the idr
When the idr try’s to boot the first relay sets to on in abaut 3 or 4 seconds and after about on or two minutes the led on ace stars to blinking, and never starts the other relay and system lock never light.
I’ve reset the net on idr and on surface and the error stays the same, the surface not conect to the idr.
Regards
Sam A&H
Fernando Lopes
does everything have the same firmware version?
greetings from hamburg
Hi Fernando
Please contact your distributor or A&H technical support who will be able to help you resolve your issue.
https://allen-heath.helpserve.com/
Please include the answers to my previous questions asked and a detailed description on the exact problems you are having.
Regards
Sam A&H
