Ilive 144 rab2
Hello I have problems for connect my surface and mix rack I am use the ace connect bud the mix rack is failed connect I have the ilive 144 and rab2 module the mix rack is 48 I can’t connect. But I can connect if I use the network connection. Please help me. Thanks
Is this a new setup, or is this something that has been working and now has stopped.
If you’re using the RAB2 module, you need to make sure that the ‘Bridge Control Network’ socket on the ACE card in each unit (surface and mix rack) is connected to a ‘Network’ socket on the associated CPU card. This is shown in the bottom diagram on page 2 of the ACE card fitting notes here: https://www.allen-heath.com/media/ap7652_2+M-ACE.pdf
Hope that helps
  • Jeff, A&H
Thanks I use the bridge this week thanks
Hello I need you help please I use the bridge but I can’t connect the surface and mixrack I show you picture
Hi sinfronteras,
Your profile says you are based in Peru? If so, I’d recommend getting in touch with our distribution partner, Sonotec, as they are best placed to support you on this.
Alternatively you can send an email to support@allen-heath.com with all the details.
