Hai, Can anybody tell me how to setup ilive 176 modular with IDR 10 with Ace card option Remote Audio 2. Its urgent please.
Its saying control failed.
As it is ACE i connected only one cat 5 cable. But its not working.
Where are you based? I’d recommend you contact our local distributor for immediate assistance, but here are a few tips:
Remember you can always drive the iDR off Editor or MixPad should the Surface still fail to connect.
Should you need clarification on any of the above, check out the iLive training videos on our Youtube channel.
Hope this helps.
Thank you so much Nicola. I will try this today.
I am working in Dubai. We have a client who has bought iLive176 (modular) with IDR 10.
The IDR 10 is the old black one with ACE card option, not the new blue Rack extra 2.
The problem is there is no sound coming from the output. Through the headphones also. The Signal is showing in the channel and in the master fader.
We did the connection as you said. One cat 5 cable from the idr 10’s ACE 1 to the ilive 176’s ACE 1. They have also connected a cat5 from the network 1 to bridge control network of ACE card on the idr 10 as well as the surface.
They have resetted the 176, idr10 and the touch screen and its ip address shows
Mix rack - 192.168.1.1
Surface - 192.168.1.2
Touch screen- 192.168.1.3
Firmware versions are - touch screen - 1.83
surface - 1.83
Mix rack - 1.83
Then i told them to select channel 1 and assign the channel by going to preamp and selcting idr mix rack slot A 1. The signal is showing in the channel and also at the master faders. The client wanted the output from the mixer’s local output. so just to check they have assigned D1 and 2 as main L R by going to the output page. its patched and applied. But they say no sound is coming through the speaker. there is no sound coming from the headphones also. In the output page on the heading port A ace its showing channel 33 and redundant link currently enabled.
Is there anything that i am missing, that i need to do. Please guide me Nicola.
You should really contact Tech Support. Please submit a ticket with all the information above to our UK Support team here:
https://allen-heath.helpserve.com/default/
I did Nicola. Yesterday afternoon. My ticket #MYR-140-86338. But havent got a response till now. The client is calling me. Is there any other way to contact them like through skype or something. Thanks.
I got a reply from Allen Heath Technical support yesterday evening to send the showfile. Thank you Nicola for your help.
