I have a 144 control surface and an idr10 for master and an idr32 for slave. My idr10 is used for wireless inputs (musical theatre situation) and my idr32 is used for orchestra inputs/main outputs. I would like to be able to allow my drummer to mix his own monitor via mixpad, but it only controls the first 64 channels. I cannot get control to him of the instruments in his mix. Can I use ace to send direct outs of 65-85 to channels 33-53? Thanks. I am using these in dual mixrack mode.
The app will only ever see the main rack so only the first 64 channels and not the second rack or expander.
How many inputs in total are you using from both racks?
If it fits within 64 then is it not possible to just use say the first 32
from the idr10 for your wireless mics etc then set up inputs 33 upwards
so the input is patched from port B which is the second rack?
Should just be a whole bunch of input patching
If you use more than 64 inputs then just fit what he needs in his monitors
within the first 64… Although I think 65 and up can only be sourced from the
second rack…
Save your channels in libraries and don’t forget to tick recall head amp gain
I’ve not used dual rack in ages but I think it should work that way…
I tend to use dante to fire stuff between racks but that limits you to 64
Channels anyway…
Good luck
