iLive Editor for Linux
We just ordered a mixrack, and would really like to use a tablet running linux to control it. Is there any reason why offline and mixrack only is not supported on linux? For now, we’ll have to settle for windows 7.
IDR32, PL10, Dell Latitute XT tablet
Our adventures with this setup: https://gonnagles-engineering.blogspot.com
Hello All
RE the offline support for Linux, the app is mainly Java, but the offline portion is written in non-open source c++.
On the window release we compile a dll which the Java opens a socket to. Situation is similar on the mac with a dylib.
For Linux because of all the different flavours, you would need the same gcc / glibc that we use to compile the so library.
This isn’t impossible, but its a lot of time for us to compile the offline library for every different flavour of Linux in use by iLive customers.
We could lets say just support the latest incarnation of a popular distro, say Ubuntu, but there would have to be sufficient interest, and be on the understanding that we’re not going to support all flavours.
Hope this helps.
Andy
A&H
I see your problem. Support for Ubuntu 10.04 would be wonderful. I think that any engineer taking this seriously should run the editor on a clean and dedicated installation. If you could provide a version that works for Ubuntu 10.04, then I’m sure someone (me for example) will create a bootable USB image with that distribution and the editor, for the convenience of others.
Best,
Frank
I also understand your problem supporting multiple distributions. I worked with Linux software vendors in the past who had to deal with this. They would generally pick one or sometimes two distributions to support. While this changes over time, the current best distribution to support is Ubuntu. The distribution supported is less important than having a well supported Linux option!
Regards,
Mark
I don’t know anyone using Linux on the desktop for audio applications that isn’t using Ubuntu.
Its the logical choice because of special media version available and the plethora of audio tools.
Software developers running Linux don’t generally run Ubuntu, but most end users do.
If there was a Linux only distribution that ran on Ubuntu, then its 99% likely that it would also run on Debian which is reasonably widespread. Ubuntu has more than 50% of the linux market share, and way more than that if you only count desktops / laptops.
On that note though, I hardly ever use offline so its not the end of the world. It would be nice to have an Ubuntu distribution of the software though, even if offline does not work. Is anyone keen to do this?
