iLive firmware V1.50/1.51 running on older systems
Dear all,
Some iLive users have experienced problems with iLive system speed relating to channel naming with V1.50 or V1.51 firmware. This only affects older systems which use a 1.0 GHz control surface Touch Screen Computer.
We are working on a V1.52 maintenance release which will fix this problem for 1.0 GHz Touch Screen Computers. This firmware is expected to be released by 10th September.
If your iLive control surface has a 1.0GHz Touch Screen Computer and you are experiencing problems since uploading V1.50 or V1.51, you can revert to V1.43 firmware until the new firmware is released.
Please be aware that in doing so, any shows that have been prepared in V1.5 will not work. You should revert to your V1.43 shows. V1.43 can be downloaded from www.ilive-digital.com/firmware This page also has instructions on how to check which Touch Screen Computer type you have in your iLive system.
Rgds,
Debbie
Allen & Heath
