Hello,
I’m using iLive 144 and I have PowerBook G4. I had system 10.4, but it worked only online (there was only one option to choose). So, I installed 10.5 and I have all three options. I press the “Offline” and I have a window with “select surface type, hardware config etc”. But when I press “OK” button, nothing happens
On my MacBook Pro everything is allright, but in work with sound I use only PowerBook (MacBook is too expensive for me for live situation
). Could you help me?
Thanks, best regards
PS Sorry for my English, I can’t speak well
This is log from Terminal:
Last login: Mon Jul 6 23:56:36 on ttys000
PowerBook-G4-12:~ mateusz$ /Users/mateusz/iLive Editor/iLive_Editor ; exit;
Exception in thread “AWT-EventQueue-0” java.lang.UnsatisfiedLinkError: /Users/mama/iLive Editor/idr-livesim.dylib: no suitable image found. Did find: /Users/mama/iLive Editor/idr-livesim.dylib: mach-o, but wrong architecture
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1822)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1702)
at java.lang.Runtime.load0(Runtime.java:769)
at java.lang.System.load(System.java:968)
at com.allenheath.ilive.cSim.(cSim.java:95)
at com.allenheath.ilivesystemmanager.ciLiveSystemManager.ConnectToUnits(ciLiveSystemManager.java:771)
at com.allenheath.ilivesystemmanager.cNetworkConnectionsWin.StartConnection(cNetworkConnectionsWin.java:311)
at com.allenheath.ilivesystemmanager.cNetworkConnectionsWin.NextOKAction(cNetworkConnectionsWin.java:432)
at com.allenheath.ilivesystemmanager.cNetworkConnectionsWin$cNextOKButtonMouseAdapter.mouseReleased(cNetworkConnectionsWin.java:470)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:232)
at java.awt.Component.processMouseEvent(Component.java:5602)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
at java.awt.Component.processEvent(Component.java:5367)
at java.awt.Container.processEvent(Container.java:2010)
at java.awt.Component.dispatchEventImpl(Component.java:4068)
at java.awt.Container.dispatchEventImpl(Container.java:2068)
at java.awt.Component.dispatchEvent(Component.java:3903)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3936)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
at java.awt.Container.dispatchEventImpl(Container.java:2054)
at java.awt.Window.dispatchEventImpl(Window.java:1801)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
logout
