iLive wireless control setup?
We use the iLive t-112 with IDR 32 in the closet, wired connection across a small gym sized room. Wanting to be able to do some of the wireless control via iPad, but I haven’t seen anywhere to show exactly how that would be all plugged in. Where in the chain would the wireless router go? Do you put the wireless router between the ACE ethernet connection, or to one of the network ports on the IDR and leave the ACE wired?
We want iPad/iphone control, but I’d rather leave the connection to the console wired if at all possible.
wireless router connects to network port (either on idr or surface) ACE is only to be used between surface and IDR. and it (ACE) should be wired…
RayS
R-72/iDR32/iPS10
Awesome, exactly what I needed to know.
I’d recommend you connect directly to the iDR not to the surface. I tried a wireless router connected at my T-112 and I had lots of connectivity issues. When I set it up directly to my IDR-32 it was rock solid.
-d
Had the same issue… Connecting to iDR was better
Gil Parente
Design & Integration
Entertainment Arts, Inc.
iLive 176, T112
iDR48 , iDR16, iDR10
Multiple iPads
Dante
Etc…
