Hi. We recently installed a 64x64 Dante card into our SQ6. We powered off the unit, installed and powered back on. It doesn’t show up under the I/O options. We assumed we needed to update the firmware. We are on 1.5.7 and 1.5.10 is available. We’ve tried multiple USB drives (even ones we know we’ve used for recording) and tried multiple firmwares between the two versions and we consistently get “image not found” on the Firmware Update page. We’ve formatted the USB drives with the console, moved the .bin file to the root of the drive and tried the update without success. Please let me know if you have any suggestions! Thanks!
Just to be sure, you did unzip the file you downloaded from the site?
Had a few who missed that step, as windows have a tendency to hide the .zip unless instructed to show filetype.
The file is not zipped. It’s an .bin file. Thanks!
Just wanted to make sure, as I have seen people copy the downloaded .zip file onto the USB key without unzipping it.
A few other things that “might” be connected:
The USB key is formatted on the console ?
And naturally you have the correct console type of update (SQ5, SQ6, SQ7)
Yes, tried 4 USB drives, all formatted by the console. 2 we’ve been using regularly to record audio from the console.
Yes, doubled checked that also that we are on SQ6 firmware.
Thanks for both ideas.
Update on the Dante card if it matters: It’s a 64x64 V3. I assume I need the firmware update due to it being a V3.
If you are trying to update the console’s firmware, are you following the SQ Firmware Update procedures to the “t”? https://www.allen-heath.com/media/SQ-Firmware-Update-Instructions.pdf
If you follow those instructions and still get this error, it is likely an incompatible USB drive. This is not uncommon and it’s possible that all four of your drives are incompatible, especially if they are from the same manufacturer or came with “special” software on them to make backing up things easier, etc. That type of software is usually installed on it’s own boot partition which can cause issues too.
Update on the Dante card if it matters: It’s a 64×64 V3. I assume I need the firmware update due to it being a V3.
Yes. You need to be on SQ Firmware 1.5.10 before the “V3” Dante card will be recognized by the system. The V3 cards, while having the exact same specs/capabilities of the V2 cards, do use different components (ie chips that are actually available today) and the console needs that firmware (or later) before it card will be recognized by the system. So your experience with the card not being recognized is 100% due to this issue.
I feel I’m following the directions exactly. I’ve used two different “types” of USB drives, two we’ve been using regularly for recording from the console. None have any built in software. Formatted by the console. I plan to try some other USB drives and the same process using a Windows computer.
SOLVED: After 9 different USB drives, one finally worked. The only think I can think of is it is a 4gb drive. Some others were larger.
I am having the same issue. I have tried 3 different brands.
I have tried multiple sizes and I can’t get it to update.
I am trying to move from 1.5.4 to 1.5.10 and even tried 1.5.5
Nothing works. Any ideas or Flashdrive brands anyone has used to be successful? I have an event in 2 days and I need the Dante V3 card but it won’t work until I get the firmware up to date. Please help
While I can’t be sure this is the problem people are experiencing, I think the fact that a lot of these flash drives come with pre-installed shit, I mean “free software” on them causes a lot of the incompatibility issues. This software is usually for backing up or recovering data and it’s usually on its own boot partition. You really need to make sure all the “extra” drive partitions are removed and you have just a single “data only” type partition.
Issue resolved.
The problem is with Apple’s new OSX. It creates a metadata tag file when you move the files over that can’t be seen on Apple but you can see them on a PC. The workaround is to copy the files from a PC not Apple until they can fix this issue.
or the problem is A&H’s code that freaks out when it sees something it doesn’t recognize.
Installing a firmware is something that can easily “brick” a device if it is done incorrectly. I can absolutely understand why A&H would have such a strict adherence to file structure and file types in it’s update programming. Having “something the system doesn’t recognize” could easily lead to completely inoperable equipment due to a failed/corrupted update process.
Thanks the MACOS tip worked for me as well. Maybe good if A&H states this as a well know problem in their install guide? Would save a lot of us Macbook owners a lot of time ![]()
Wow. Glad I found this thread. But at the same time, trying to update the firmware right now sucks. I guess I’ll see if Parallels will do the trick.
I am confirming, that copying the firmware *.bin using Windows Explorer in Parallels worked for me.
Problem fixed, try downloading the firmware file through a Windows PC, not from a Mac, the error is in the MacOS code.
I am quite sure, that there is no bug in MacOS…
Thanks so much for posting that about Mac OS! I tried a number of drives too, but when I used a windows PC, it immediately worked.
