Hi all. I would like to use Avantis with Immersive audio, but I see one big problem. Avantis direct out signal doesn’t listens to VCA. Without this feature it’s impossible to work in Immersive audio. In my opinion this should be fixed-updated, signal path in follow fader mode should listen to VCA as well.
Do you have your global direct-out point set as “post delay”?
Sure. As I mentioned before, it listens to channel fader, and if this channel is assigned to VCA - nothing changes. You can play with VCA - nothing.
