I’m a bit confused on how the in-ear monitor stations receive information from the desk. We have the personal monitors and distribution hub and I’ve noticed that when scenes are loaded, the key-mappings on the monitors are changing. Actually, I’m not certain that it’s a result of the scenes being changed, but that’s the only thing that’s changing on the desk.
For instance, our drum group on most of the in-ear stations has all of the drum’s input channels added, but when I switch scenes, two of the channels are removed from the group. When I switch back to the previous scene, the removal sticks and they aren’t added back.
Can someone shed light on what’s happening? Thanks.
I’ve tested it now and it’s not making a difference. The names are being transmitted to the ME-U as I can see them sync on the web interface and on the ME-1’s but what’s happening is that two of the channels that were previously in a group of 6X on the ME-1 have been removed and the group has been reduced to 4X. I can’t seem to prevent this from happening.
There doesn’t seem to be anything different about the channels on the QU-32. We have 1-5 set as Drum inputs with cannel 13 as the overheads, so 6 total inputs grouped on the ME-1. What could be causing this?
Should be simple to re-create. Just create two scenes. One with channel strip 1 and 2 unlinked and one with them linked. On the ME-1, group channels 1 & 2.
When you switch to the scene with the linked channels, the 2nd channel will be removed from the group on the ME-1.
Logically, I think this makes sense, since I wouldn’t need two independent channels on the ME-1 to be grouped when I could simply have one that’s receiving audio from both 1&2.
The only thing it does is create an organizational problem for the musician.
What I haven’t tried yet is re-booting the ME-U after the scene is switched to see if it will bring back the groupings. Also, recalling the configuration for the user on the ME-1 seems to fix the problem as well.
When you link channel 1 & 2 on the mixer, these are seen as ONE stereo channel at the ME-1 end. Therefore as you say, this is expected behaviour. Channel 2 is removed from the group because there is no longer a channel 2. It becomes the right side of stereo Channel 1. With a single level control as you would expect for a stereo channel.
