Incorrect Type in GetLEDColourForType
Greetings,
I’m getting nasty pop-ups while running iLiveEditor v1.51 in offline mode.
Reproduceable steps:
Load Editor
Recall my show
No pop-ups appear
Recall FOH_LCR__ show template
Recall my show
Four or five pop-ups appear
Several of my custom strips have dissapeared from each tab.
(The problem also occurs if I delete the custom strips and tabs and rearchive the show.)
Rinse, repeat.
Thoughts?
Tim ==
Hi Tim,
I’ve received a copy of your show and have reproduced your problem here.
The pop up messages you’re receiving aren’t critical, and once you’ve pressed ok on them your equipment will continue to work correctly. We’ll work on a fix of this for the next version.
As for the custom strips, these aren’t currently stored in shows, so when you recall the FOH_LCR__ show you’ll lose any channel strips for channels which aren’t in the new mix config.
I hope this helps?
Colin A&H
Thanks, Colin. Good to know those messages are benign.
